WARRIOR FENDER EXTENTIONS/FLARES?
My back tires are picking up too much mud and I end up wearing it.
Are there any manufactures that make fender extentions/flares for a Warrior?
Has anybody made their own?
I willing to trade a little looks for less mud!
After insalling an aftermarket wider axle, I was always getting hit with clumps of mud on the back of my helmit, and man that will drive you nuts.
What I did is,,,, picked up a rubermaid garbage can, not the hard plastic kind the big round (grey is what I used) flexable rubber ones. I have a 92 and the gray matched the stock front fender extention, see if you can match yours, and I picked up some rivits and paited the heads black to match the rivits up front. I thain got some carboard to practice with, I highly recomend experimenting with carboard first. You can also use the carboard mockups to figure out the best way to cut them out of the garbage can, also I think the large end of the garbage can works better the larger diamiter will fit the feder better. Also, use washers underneath the new fender extentions or the rivits will pull through the soft rubber. I cant remember if the rivits came with washers, but use them.
