oil in airbox
Old Apr 9, 2003 | 05:18 PM
gumby's Avatar
Default oil in airbox
i noticed there is some oil in my airbox is this a cuase for concern there is about a 1/4 inch, i have a 2003 honda 350 4X4
Old Apr 9, 2003 | 06:51 PM
RINCON's Avatar
There is a crank case vent tube that is vented into the air box. Mabey you were running up a steep hill, or it was over full on oil?? I don't think it'll hurt anything, but I know what you mean though, it's not suppose to be there.
Old Apr 10, 2003 | 06:44 AM
dusty's Avatar
Gumby,
It is not all uncommon for a new motor to produce a little blowby until the rings fully seat. I Dont know how many miles you have on it, but being an 03, probably not alot. I wouldn't worry too much. Just keep an eye on it. It should go away with more ride time.
Brian
Old Apr 10, 2003 | 07:07 AM
gumby's Avatar
it has 1300kms on it, im going to soak up the oil in it and see if anymore appears this is the first brand new bike a had, ive never had this problem before so i was just wondering if anyone else has noticed this
Old Apr 10, 2003 | 01:16 PM
Coyotechaser's Avatar
The air filter is supposed to have oil in it. Maybe some came from the filter. There shouldn't be that much though. When preparing the atv for sale. Could the garage have put too much oil on the filter or does the factory handle that? Just a thought.
Old Apr 10, 2003 | 08:07 PM
hounddog's Avatar
I agree with you, Coyotechaser, the dealer probably went a little monkey with the amount of oil they put on the filter. If memory serves, you're supposed to soak the filter in gear oil (80w90) and gently wring it out before you put it back on. I've got an '02 Rancher and I had a bit of oil in the moisture collector on the bottom of the airbox for the first hundred clicks or so, then it went away. What ever it is, judging from the amount of people this happens to, either Honda is a secret subsidiary of Harley Davidson, or this is perfectly normal.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 10, 2003 | 09:32 PM
dzzy's Avatar
They get overfilled alot I think. It's kind of a strange engine case arrangement. It's a dry sump, like a 400ex or rubicon, but the oil tank is inside the cases. If you don't let the machine idle for 5 minutes on level ground before you check the oil you will have the wrong amount of oil, probably too much. I've seen some problem in very cold weather too, with the crank vent, the big hose from the engine to the airbox freezing up, especially where it joins the airbox. You should find a small maybe inch square foam filter there. If it freezes in that area, it can pressurize the cases and the oil will come out where it may, often in the airbox. I have also seen shifter seals popped out from this. Also I have been told that in cold weather, when your engine oil is thick, it is prone to ending up in the airbox if you don't let the machine idle or run very easy the first 5 minutes or so.
Old Apr 10, 2003 | 09:42 PM
RacinJason's Avatar
I've seen it happen, but only on a machine that was rolled.
Old Apr 26, 2003 | 10:06 PM
cluby's Avatar
listen to dzzy everthing he has said is 100percent ture right from Honda
Old Apr 26, 2003 | 11:10 PM
thor440's Avatar
To get an accurate reading of your oil, you must first warm your motor. The oil will expand and read higher up on the dipstick. If your oil is completely full when cold, when it gets warmed up, it is to much.
