250EX !!!!!!!
Old Apr 9, 2003 | 10:06 PM
4rider's Avatar
Default 250EX !!!!!!!
ive been wanting a 250ex for a while now and wanted to know if anyone has one or if anyone has had some experiences with one. If i get one i plan on putting some mod exuast and some K&N kits and maybe some armor. if anyone has some good modification suggestions than that would be cool to, and if anyone has some suggestions and some advice on it than it would be a great help. please give me some info to help me in buying my 250ex. thanx
Old Apr 10, 2003 | 12:27 AM
scosho's Avatar
I considered doing everything from snorkle circumcision to powroll.com's big bore kit. Then I found a Suzuki quadracer for a thousand bucks that more than meets my Need For Speed. So I opted for reliability and ease of use on the EX, since it is the wife's machine mainly. I put the Outerwear fabric airbox lid replacement on, went with a 92 jet @ 5000' elev, it runs as strong as we need. If I were to add exhaust, I'd spend the extra to get the header pipe along with the exhaust upgrade. I'll probably put a ProMotion twist throttle on it because her thumb hurts on the standard throttle. I may put durablue wheel spacers on the fronts to make the front tires 3" farther apart, as stability is an issue. It is what it is, so I decided not to spend a chunk barely making it what it iisn't. Hope that helps, the 250EX is GREAT as it is.
Old Apr 10, 2003 | 12:35 AM
maddog56's Avatar
if you are really concerned with making the 250 faster, you might just want to buy a 300ex.
Old Apr 12, 2003 | 11:51 AM
250EXRiderJamie's Avatar
If you put the mods i have on it(in my profile)then it will be faster then the 300EX...My friend has a 300EX and with my pipe and K&N Filter and jet kit and all that crap it seems like mine has more power...no offense Jay it just seems like that...Putting mods on quads are fun too so if you want something with O.K speed with mods i recommend my quad
Slone
Old Apr 12, 2003 | 01:38 PM
RPM's Avatar
RPM
If you get the April 2003 issue of ATV Action, there is an article on page 56, titled "Duncan Racing Project Honda 250EX". There is a lot of good info there.
Old Apr 12, 2003 | 10:16 PM
maxamillion's Avatar
go with the pro circtuit t 4 full system. it adds power throught out the entire power band. the k&n air filter helps alot to , i bought outerwear for it and took the airbox lid off so more air can flow through it. diff tires will help u accelorate alot faster.
01 250ex
DG alloy nerfs
DG alloy front bumper
pro circuit t4 full system
k&n air filter and prefilter,air box lid removed
razr rear tires
Old Apr 13, 2003 | 10:02 PM
racer6's Avatar
The 250ex is a very reliable machine. BUT I dont recommend rear wheel spacers because they put to much stress on the rear axle on the left side. I've had to replace ours twice already, After my 12 year old son bent the axle coming down off of a 3 ft jump! The axle is made of light weight aluminum and cant handle the extra leverage the rear 2.5 durablue spacers put on it. The front 1.5 spacers though really help the quad handle better! I talked to honda directly about the axle problem, but they told me the quad wasn't designed to be jumped like that! After the 2nd axle was replaced, I took off the rear spacer kit and left it stock he hasn't had any more trouble with it! (over 1 year now). Other than changing the oil religiously every 5 hour of riding ( due to the autoclutch trans needs clean oil to last a long time) its a excellent machine all around, and I would recommend it to anyone!
hondarider1234
Jul 21, 2015 11:53 PM
cSchwartz
Jul 9, 2015 02:40 PM
Rider252
Jul 6, 2015 03:37 PM
Jake55
Jun 29, 2015 06:43 AM
DSAPP
Feb 1, 2001 09:49 AM
