Need Help In removing Master link in O-ring Chain
Old Apr 9, 2003 | 10:59 PM
SageCrusher's Avatar
Default Need Help In removing Master link in O-ring Chain
Have 95 Xplorer and trying to srevice the front chain, it is a pain to remove, so I wanted to to remove the master link and clean the chain. But after endless attempts to pry out the backing plate, I gave up....
Idea's?
Can I just go to the car wash and blast off the crud?
I have been using the spray on "Tacky" PJ1 for years and the crud build up is ugly!!
Thanks in advance!
Old Apr 10, 2003 | 12:04 AM
PRAIRIETWIN's Avatar
Grind off Master Link pen ends with hobby grinder, remove link and chain, clean, then replace chain and add new master link.
Old Apr 10, 2003 | 12:36 AM
The master link I'm working on has a removable sleeve, and exposes the pin's..I think the O-rings are holding the side plate in place....I don't think this need to be grinded on, as it is ment to be re-used.
Stock chain (OEM)
Old Apr 10, 2003 | 12:40 AM
NCScrambler's Avatar
Just checking, but have you put enough slack in the chain to aid in removal of the link??? Very important if you have not.
Old Apr 10, 2003 | 01:48 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
buy a chain breaker
small, handy little tool.
It only gets used so often,,,,,but its nice to have when you need it
I think i paid like $30 for it
Old Apr 10, 2003 | 12:57 PM
Chain is in the most slack Position, I can move the links very freely
Is it OK to just car wash the chain on the ATV?
Old Apr 10, 2003 | 01:06 PM
I wouldn't pressure wash it because you can cause damage to the o-rings. Just scrub it with it on. Use a light degreaser or WD-40 or something of that nature along with a brush and scrub it with a brush. Just don't leave the degreaser or wd-40 on for long to minimize damage to the o-rings. The only other way I could think of removing the link would be with a punch trying to push the pins through the link. You could also use a small screwdriver to pry the piece out, but be careful not to damage the o-rings. Oh yeh, kerosene is also good at cleaning that crud off of the chain.
Old Apr 10, 2003 | 01:22 PM
here we go with the sporcket trick...Keep you posted.
Ya I thought the carwash was a bad deal....
Old Apr 11, 2003 | 01:11 AM
NC,
well your trick did work.....Banging on the Master link while in the sprocket top gave me the edge..
however, after I replaced the master link (Bought a new one) it sure is tight, the chain where I put the master link binds somewhat, hopefully it will loosen up after some torque is supplied to it.[img]i/expressions/face-icon-small-wink.gif[/img]
Thnaks again for the help- let me know if the binding is something to be concerned about.
Old Apr 11, 2003 | 02:23 AM
You are welcome, I am glad the trick worked. I think the link will be ok, should loosen up after riding a little, just keep your eyes and ears on it to make sure. You probably just messed up one of the plates a little while punching it out, should not be a big deal, should work fine. You may want to roll it back and forth a couple of times and make sure it doesn't bind up enough to jump the sprocket or anything, but I think after a little breaking in, it will be good as new. So, to the original question, is the chain all nice and shiny now??? LOL
