Bigger carb boot for 91' lt250r
Old Apr 11, 2003 | 03:53 PM
chuck1221's Avatar
Default Bigger carb boot for 91' lt250r
I'm just about done putting my motor back together and was wondering if anyone knew where I could get a bigger carb boot for my quadracer. I have a kehin PWK 36 carb and it is a tight fit in the stock boot. What have all you guys with bigger carbs did for this?
Thanks Alot,
chuck
Old Apr 11, 2003 | 06:32 PM
dual-sporter's Avatar
since i never actually put a bigger carb on my '91 i can't say too much... but on a 36mm carb you should be able to soak the boot in boiling water then put it on the carb and it will work.
one other solution (usually for larger carbs like 38-39mm) i've heard is using a carb boot from a LT500
Old Apr 12, 2003 | 04:26 AM
Kiwi_Craig's Avatar
I managed to squeeze a 38mm PJ into my 92's standard boot, once in try a little bit of gentle heat gun on it but be CAREFULL this allowed a bit of give, no probs 3 years later.
Apparently the 88 / 89 LT 500 boot is a bolt on but is actually a bit loose on the 38mm PJ / PWK ? the stock 38mm Mikuni spigot is larger ?
Kiwi
Old May 5, 2003 | 12:36 AM
chuck1221's Avatar
Does anyone else have an idea of where to get one?
I searched the forum and someone said they called sudco and they had them. I called there and they didn't have them for the lt250r. Mine is starting to crack from age and is going to have to be replaced sometime. If you buy a RAD valve can you get a larger boot for that?
chuck
Old May 5, 2003 | 02:10 AM
Icehouse's Avatar
I have a 39mm carb on my lt250 and I purchaesd a rad valve from boyeson. I went to the hardware store bought a thick peice of rubber tubing and it works great. Its cheap but you need to buy 2 hose clamps to keep a tight seal on both sides.
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
tporath
Jul 11, 2015 12:31 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
