Predator w/b pipe (new owner)
Old Apr 15, 2003 | 01:53 AM
blkbird's Avatar
Default Predator w/b pipe (new owner)
I'm a new owner of the predator.(2days). I have a white bros. pipe (slip-on) on order.. I was told all I needed was to move the needle up/down so it gets more fuel.. with no re-jetting. I would like to know if this is true from other predator owners that put the w/b pipe on.. thats..
Old Apr 15, 2003 | 03:44 AM
aussiequadrider's Avatar
G'day Blkbird.
Congratulations on your exciting purchase.
Mate you may not need to do any changes.
This forum is full of guys who have your setup without issues.
Ride and see what it's like and hopefully you won't be able to wipe the smile of your face.
Report back and you'll find a lot of smart guy's out there ready to help if you need it.
Good luck from down under, Geoff.
Old Apr 15, 2003 | 06:29 AM
Firehawk1970's Avatar
I'm at 200 ft. above sea level and with just putting slip-on on I didnt have to rejet and got a big improvement. I am running 5 discs no spark arrestor or quite core. When I did add K&N I did have to rejet. I have 160 main in her now and she is strollin....
Old Apr 15, 2003 | 06:34 AM
Y2JRaptor660R's Avatar
Hey, a bit more Down under responce on the forums!, Great to see[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 15, 2003 | 10:18 AM
TLDPredator's Avatar
Check into www.Esuperbikeshop.com for their Airforce kit for the airbox.
Old Apr 15, 2003 | 12:43 PM
ProXPredator's Avatar
If your going to throw on the slip-on, it would be in your best interest to get a K&N and then rejet it. I'm still stock jets on mine, with the K&N and slip-on. It's running great, no popping or anything. I'm thinking of going to a 155 just to see if it makes a difference, but not sure yet. It was running great this winter, where the air is a little thinner, so I'll see if there will be a difference as it warms up.
Old Apr 15, 2003 | 01:36 PM
modquad's Avatar
Or you can grab a $6-8 pack of six Univents, and mount them on the rear of your airbox. Like ProX said, get the K&N, make sure to take out the stock foam pre-filter.
Old Apr 15, 2003 | 06:17 PM
DuneRocket's Avatar
Ya but those uni-vents dont look as good as the A/F kit..........its all about the look plain old black plastic or anodized aluminum in the color of your choice.
Old Apr 15, 2003 | 06:31 PM
SP700RACER's Avatar
The Airforce kit is designed the way it is for engineering reasons. Without giving away Gary's secrets, the size and location of the plates are critical for maximum performance. Just cutting holes and increasing the main jet will increase performance,but it will not match the Airforce kit. I basically had the same set up as everybody is describing (air vents and 155 main jet) before we added the Airforce kit. We dynoed it before and after, the kit made enough difference to more than justify the $99.00. You will not get more gains from any other mod for the money. Gaurenteed !!!!!!!!!!!!!
Old Apr 15, 2003 | 06:39 PM
DuneRocket's Avatar
I agree with you there SP700Raceer it made a bike diff. on mine too!! How do you like the 580 kit ? did you get the cams and all the other good stuff to.
