Why Can't You Use The Dyno Jet Kit For V-Force
Old Apr 15, 2003 | 11:08 AM
NYVForce's Avatar
Default Why Can't You Use The Dyno Jet Kit For V-Force
Why Can't you use the Dynojet kit for a 03 praire on a V-Force if they have the same carbs. I'am putting on the hmf dual exhaust, and I want to drill some hole in the air box lid and put a piece of hose on the air box till I get a diamond g snorkle but I don't think the jets that come with the pipe will be big enough will larger dynojets fit and is the needle not the same. Hmf said to put a washer on the needle for there pipe so I could probably use a bigger washer. Am I totaly wrong? Thanx
Old Apr 15, 2003 | 12:07 PM
mtecate4g's Avatar
dyno jet kits are specifically tuned for each model. The needle angles would be different the instructions on jet sizing would be completely wrong and so forth. Just go to your dealer and by some bigger jets. You shouldnt have to shim the needle any more with the snorkle mods.
Old Apr 15, 2003 | 01:54 PM
Vforcer's Avatar
I did what HMF sugested .... and it worked very well.
I did add more fuel ... using the dial-a-jet .... and then more air ... it it runs very well.
I am not feeling any need to take the carbs apart to change the needles .... it is very
smooth through the whole power band as is.....
Hope this helps
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Cantbuytime
Aug 17, 2015 06:33 PM
cspyy
Dec 27, 2000 12:14 PM
Blazin_Banshee
Jan 21, 2000 12:16 AM
