After Oil injection removal
Old Apr 16, 2003 | 06:58 PM
duneaholic's Avatar
Default After Oil injection removal
When you get rid of the tank can you just relocate the CDI box to another spot.? And also when you get rid of the oil low sensor will this light come on or does it just not work after you remove it.? Just trying to finalize everything. Thanks Shawn.
Old Apr 16, 2003 | 10:49 PM
duneaholic's Avatar
Anyone ran into this?
Old Apr 16, 2003 | 11:40 PM
modquad's Avatar
The low oil light is a normally open circuit....need the switch contacts to light up. I've left the ignition alone. But I did relocate the battery up front and the starter solenoid. All the stock wires will reach. If you're gonna go that route, I'd remove the starter, mill the flywheel, and loose the battery in favor of W/B's battery eliminator kit.
Old Apr 17, 2003 | 12:15 AM
duneaholic's Avatar
The CDI box was mounted on top of the oil tank. I just moved it to another spot. All wires reached just fine. I do like the electric start but it does start first pull every time I've tried it. Thanks.
Old Apr 17, 2003 | 11:35 AM
Farmr123's Avatar
Be sure to tape up the connection where the low oil sensor was plugged into. If it gets wet, it can make the oil light flicker, which can be very aggravating.
Farmr
Old Apr 17, 2003 | 12:02 PM
modquad's Avatar
Sorry Dune, they've changed that since I did mine. Along with what Farmr suggested, a product called liquid electrical tape (available at Menard's, Home Depot, etc) works good for sealing things up.
Old Apr 26, 2003 | 11:07 AM
paulywally's Avatar
You can put the CDI Box anywhere, as long as you keep it dry.
Just unhook the oil light wires and tape them over
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
