Super Cooler
Old Apr 17, 2003 | 11:30 PM
rippinrap's Avatar
Default Super Cooler
I just got the cooler and was wondering does anyone know where to install this, the directions do not seem correct. Is this mod worth the bucks?
Old Apr 17, 2003 | 11:34 PM
BlueLeader's Avatar
you install it in-line on your coolant line going from your head to your radiator.
Old Apr 17, 2003 | 11:55 PM
rippinrap's Avatar
Why is it I see so many people with the cooler in the lower line?
Old Apr 18, 2003 | 12:55 AM
BlueLeader's Avatar
oops. brain cramp. It makes sense to have it on the bottom line to cool the fluid one last time as it exits the radiator and enters the engine.
the thermostat housing is on the top and opens when the coolent in the top hose gets hot. then it goes into the radiator then throught the bottom hose into the water pump and into the motor.
put it on the bottom line [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 18, 2003 | 01:23 AM
BlueLeader's Avatar
wait a minute. who cares if it is cooled a little before it enters the engine. It is just going to heat up and stay in the motor until the thermostat opens at whatever temp it is rated at. Can a lower temp thermostat be purchsed?? I would spend the money on a temp guage and put it in the top hose.
Old Apr 18, 2003 | 03:11 AM
rippinrap's Avatar
Thanks for the help B. Leader, I'm A bit confused. So the bottom?
Old Apr 18, 2003 | 08:15 AM
03Raptor's Avatar
I put mine on the bottom. The directions said put it on the top hose...but that seemed strange to me. I wished I would thought it out more cause once I cut my hose I found a much better place to put it....which is in the front part of the lower hose a little bit after it comes out of the radiator. It's more of a verticle position and in the front where it would get blasted by alot more air....live and learn. They want $35 bucks for that hose from Yamaha....so it's staying where it is for now.
But for a direct answer to your question....it makes more sense in my mind to put it in the bottom hose
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Slagpolaris
Sep 5, 2015 09:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
metal249
Jul 24, 2015 01:00 PM
