Blaster Plug Check
Old Apr 18, 2003 | 06:57 PM
WarriorMan05's Avatar
Default Blaster Plug Check
I just put on my new reeds, and high compression gasket from Vitos. I also got a jet kit w/ a 290 and a 300 jet. When I was running just a pipe and airbox mods, I had a 280, and it ran GREAT. I put the 290 in w/ the new needle supplied from the kit on the middle clip, and it seems to have a good top end, the throttle response is lacking tho....
Any help would be greatly appreciated.
thanks
Josh
P.S.~The plug had a white tint to it when i did a plug check, and yes I had a new plug
Old Apr 18, 2003 | 07:32 PM
BLASTERDEVIL2's Avatar
you are running lean, go up to the 300.
Old Apr 18, 2003 | 10:58 PM
Ok, I changed it to a 300 jet, and I changed the needle to the next bigger clip(I believe 4th; richer). It is now probably the best it has been since the new mods, but the low is still lacking. Is this just a fuel mixture problem?? or could it still be jetting?
The plug is still light brown, and my top end is pretty good, just the low end is bad.
Thanks
Josh
Frisky2050
Apr 9, 2020 11:19 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
D-Hagz
Jul 4, 2015 02:19 AM
