question of the week
Old Apr 18, 2003 | 08:51 PM
quadwarrior02's Avatar
Default question of the week
i was wondering if it will be any harm in dumping the clutch? for example dumping the clutch everytime you wheely
or something. will the clutch get harmed?
Old Apr 18, 2003 | 08:59 PM
sixsixT's Avatar
It's a little hard on everything especially the clutch basket.
Old Apr 18, 2003 | 09:47 PM
StevieD's Avatar
i aint sure exactly what it puts strain on, but its fun as all heck!
Old Apr 19, 2003 | 04:07 PM
any more responses??
Old Apr 19, 2003 | 04:49 PM
RacinJason's Avatar
Pre-load....most of the stress will be from anything going in free motion to a impact
hmmm how do I explain
If I punch something from 3 feet away my arm/shoulder has time to build velocity...when it hits its mark this energy is displaced onto that object
same thing this time except I already have my fist up against the object...when that same force is exerted it is once again transfered, however with more of a push than an impact
Did I confuse you?
Old Apr 19, 2003 | 08:58 PM
Cox1231's Avatar
so basically what your saying is if you leave the clutch out and punch the gas to wheely it is less stressful on the engine than if you pop the clutch?
Old Apr 19, 2003 | 11:15 PM
warrior620's Avatar
Cox1231, yes it is alot better to punch it to do a wheelie than dropping the clutch.
quadwarrior02, Whenever you dump the clutch in a "high traction" area i.e. concrete it's hard on just about everything on ur bike. It is really hard on your hubs and axle splines and if your hubs are loose, (which dumping the clutch will loosen them) they will get egged out. Its hard on ur bearings too and most wear and tear is on your clutch.
Hope i helped
Old Apr 20, 2003 | 12:11 AM
so warrior620: if i just like dump it in low traction area in loose dirt with stock tires will it do a lot of harm?
Old Apr 20, 2003 | 12:19 AM
warrior620's Avatar
Worst that will happen is your clutch will go out a couple weeks earlier than usual *that is if you dump it in the loose stuff every time you ride. There is no suddedn jolt of power when you dump it in the loose stuff so its about 100 times better than dumping it on concrete.
Aug 11, 2015 11:56 PM
Aug 5, 2015 02:10 AM
Jul 29, 2015 01:24 AM
DeFox500
Jul 26, 2015 06:32 PM
Jul 22, 2015 05:00 AM
