Mojave question need help
Old Apr 26, 2000 | 11:43 PM
MojaveManiac's Avatar
I have a 1995 Mojave 250 for 3 years now and i haven't had to do anything to the chain as in tighten it or loosen it so i was wondering how do you tighten up a chain on a mojave. It is a little loose and needs tightened. I know it is a dumb question but could you please help me with it.
Old Apr 27, 2000 | 08:30 AM
Sprocket's Avatar
It's EASY!
There are two bolts on the end of the swingarm They hold the axle carrier in place. Near the bottom of the axle carrier is a small hole. In the tool kit that came with the bike is a small metal rod (if you don't have the kit anymore, you'll need to find one that will fit in the hole).
What you do is loosen the two bolts on the swingarm, place the metal rod in the hole and carefully push down. This will tighten the chain (lifting up will loosen it). Re-tighten the bolts and your done.
PIECE O' CAKE!
One other thing to be aware of, the chain might be stretched beyond adjustment. Since your bike is a '95 you might want to consider purchasing a new one. Krause Racing (Sidewinder) makes a really good line of chains at a decent price.
Old Apr 27, 2000 | 11:34 AM
KawasakiKid's Avatar
Excellent job Sprocket, but don't forget, most times if the chain is wore out, you should also replace your sprockets. In most cases they are fine, but I have an 87 Mojave with about 2 1/2" of slack in the chain, it's about time I replace both! heh heh heh
Also, I do believe the spec is 1" of slack in the chain, correct me if I'm wrong though.
Green is Mean
'87 Mojvave
'87 Tecate
'00 DS650 [Bigger IS Better]
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
