Carb info?
Old Apr 19, 2003 | 04:00 PM
racerx5x5's Avatar
Default Carb info?
Is a Mikuni HSR 45mm carb a good mod for a stock bore? Or is it too much carb.
Old Apr 19, 2003 | 04:55 PM
BillDS650's Avatar
Default Carb info?
It all depends on the type of riding you due. Flat track racing, dirt drags, high speed dunning or open desert or if you spend most of your time riding in 4th or 5th gear good carb. If not you will be happier with the HSR42. This carb will out flows the stock carb and will have better and quicker throttle response.
Old Apr 19, 2003 | 05:13 PM
lilnotts's Avatar
Default Carb info?
how much is the hsr42?
Old Apr 19, 2003 | 06:40 PM
TyreSpinner's Avatar
Default Carb info?
Doesn't the HSR42 come stock on the DS??
Old Apr 19, 2003 | 06:51 PM
BillDS650's Avatar
Default Carb info?
The stock carb is the BSR 42 has a butterfly and works off a vacuum, The HSR is a flatslide carb
Old Apr 19, 2003 | 07:26 PM
CanadianBaja's Avatar
Default Carb info?
Has anyone tried the Dual 39mm Keihins flat slide smoothbore carbs for the DS650 from Ron Wood racing? i was thinking about getting them but i would like opinions first.
Thanks
Rob
(My 1st Post)
Old Apr 19, 2003 | 11:20 PM
lilnotts's Avatar
Default Carb info?
so would the HSR 42 be worth the money?
GregM
Mar 6, 2018 06:53 AM
ltrmc02
Jul 22, 2015 04:50 AM
ghost3
Jul 19, 2015 08:46 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
