engine?
Old Apr 19, 2003 | 07:40 PM
tippxp's Avatar
Default engine?
situation: need new pistons, crank, and gasket kit. people have suggested to buy a new motor once i told them situation. would i be best off buying a new motor or rebuilding?
Old Apr 19, 2003 | 11:49 PM
Majorecho's Avatar
Default engine?
why do you need a new crank? what is the whole extent of the damage? if that is really all you need i'd rebuild, but bore it and stroke it so you get your $ worth - it really won't cost much more and your doing the labor anyway.
Old Apr 21, 2003 | 12:06 AM
tippxp's Avatar
Default engine?
i only have the top end tore down, the piston is ok, but could be replaced, which i plan on doing, the rod seems to be shot there is a lot of play up and down. i plan on tearing the bottom end down tomorrow so i will know more then. . . but if you could i would like some more info on the big bore and stroker kits...i have not worked on this motor before... do i need new jugs or will stock jug work...etc
Old Apr 21, 2003 | 12:42 AM
Majorecho's Avatar
Default engine?
carillo rod 88mm of stroke( if I recall correctly), JE piston 103mm, renikasiled and bored stock jug + gaskets about$1200
samcoe 733cc, to say the least I am very pleased with how it is running. Everything is bolt in but piston /head clearance needs to be custom
adjusted and trimmed afterall you are putting a 103mm piston into a 100mm head - it takes a little time and effort to get it right but well worth it in my book.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
