No idle on honda 85 200s...Please Help!!!
Old Apr 19, 2003 | 11:55 PM
MattWinkle's Avatar
Default No idle on honda 85 200s...Please Help!!!
Ok,
I just recently bought a 1985 Honda 200s. It ran good for the first 3 days. But now it wont idle. I have adjusted the idle screw and the needle. When I let off the gas it just dies. So i have to start it with the gas pushed in about 1/2 way to get it started. It also started backfireing. Now im not sure what to do. PLEASE HELP!!! Thanks,
Old Apr 20, 2003 | 12:30 AM
MattWinkle's Avatar
Any help would be Appreciated
Old Apr 20, 2003 | 04:04 PM
shawzy's Avatar
I had the same kind of problem with my 350x and i went out and got a carberator kit. Works like a champ again.
Old Apr 24, 2003 | 12:25 AM
looseSTOOL's Avatar
sounds to me like your mixture is off...I would get it Dyno checked and see how it is breathing....
Old Apr 24, 2003 | 05:35 PM
MattWinkle's Avatar
Umm whats "DYNO CHECKED?"
Old Apr 24, 2003 | 07:57 PM
mudroper's Avatar
hey dude mine did that not to long ago and it was caused by a crack in my bowl, dont know if it will help but take a look
Old Apr 27, 2003 | 11:55 AM
thrashed200m's Avatar
agree with above - most likely a carb problem -
I would try cleaning the carb - it's easy and has a good chance
of fixing the problem. Good chance you have clogged jets or
something else gunked up in there. Just tear it down, clean
it with carb cleaner, and put it back together again. Be sure to
get all the little orifices cleared out, including the one through
the top of the jets. I use a little piece of wire ( very fine, like a single
strand from lamp cord or speaker wire ).
ALso, if the trike was sitting a while, varnish in the carb is likely.
Or, since it was working, you might have a piece of rust or something
in the tank that found it's way to the carb. After you clean the carb,
you might want to buy a cheap little lawnmower fuel filter, and put
it in the fuel line between the tank and the carb - it will keep crap
from getting into the carb again.
Your idle mixture screw ( the little one on the bottom of the carb)
should be aorund 2 turns out from seated ( turn it all the way in,
then back at about 2 turns ). The spring loaded screw on the side
of the carb is just idle speed, not mixture. It just controls how
far the slide is held open when the throttle is released.
hugemoth
Jul 20, 2020 03:28 AM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
hondarider1234
Jul 21, 2015 11:53 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
