25" tires for Scrambler?
Old Apr 27, 2000 | 12:46 PM
rider1958's Avatar
2000 Scrambler 500, already wore out the stock tires and would like to go to 25" ITP or Titan 589 - anyone know if this would be a problem? I know it would change the handling and power, am only worried about size differences of front and rear of the stock tires versus the same sizes of the new ones I want. Any insight?
Thanks,
Ron
Old Apr 27, 2000 | 02:39 PM
Lurch77's Avatar
It should not be a problem. Check out these pictures. This guy has had 25" on for awhile now and has had no problems.
http://briefcase.yahoo.com/myscrambler
Old Apr 28, 2000 | 01:41 PM
scrambler92's Avatar
I disagree, If you keep it in two wheel drive it should be fine, but if you switch it to 4 wheel you may have problems because of the way the "on demand 4 wheel drive works". You would have to replace the front wheels and keep the front to back tire ratio somewhere close. The link that is supplied by lurch showes a scrambler that has bigger front and back tires. BTW.That is one awesome machine! Hope I helped
www.geocities.com/otherjay sign the guestbook.
Old Apr 28, 2000 | 03:03 PM
Lurch77's Avatar
Sorry if I misled you, I thought you wanted to go 25" at all for corners. That would not be a problem. You just have to make sure all four tires are the same size.
Old Apr 28, 2000 | 05:08 PM
TO_Y28's Avatar
I have 25" tires all the way around on my 97 Scrambler 500. I havn't had any problems..
Old Apr 28, 2000 | 07:09 PM
I guess after reading the original question again he could have meant front and back. Not real sure. Sorry bout that, I may have just misunderstood. By the way Lurch you have a beautifull girl. I just had my first too. When was yours born?
fordfaithful21
Dec 7, 2015 05:52 PM
89Lt250r
Sep 7, 2015 07:53 PM
switzomatic
Aug 24, 2015 12:57 PM
mitchxc700
Aug 19, 2015 02:41 AM
maxjung
Jul 13, 2015 05:11 PM
