new belt or black spring or both???
Old Apr 20, 2003 | 11:05 PM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
Default new belt or black spring or both???
My belt used to squeel a bit at idle, but now it chirps on takeoff sometimes. Just the other day I got it stuck pretty bad in some gooey clay mud and it chirped the belt alot in reverse and low, and would barely spin the tires. That's when I pulled out the winch. Anyhow, what should I do? Get the black spring or new belt or both? Also should I clean the sheaves with something?
Thanks for any suggestions.
Old Apr 21, 2003 | 12:08 AM
mudseeker's Avatar
Do you have any shims in now ? If so take them out. If not you need a new belt. My bike was just doing the same thing without any shims with the black spring so I replaced the belt. problem solved.
Old Apr 21, 2003 | 09:07 AM
Roofer's Avatar
Nope, I haven't removed any shims. I haven't taken it apart at all yet.
Old Apr 21, 2003 | 10:58 AM
Andy~G's Avatar
Sounds like your belt is in need of adjustment.
I would do that first and put in a black spring at the same time,but the spring alone wont fix the problem.
Andy
Old Apr 21, 2003 | 02:32 PM
Nemmeh's Avatar
Yeh, do exactly what andy G advised you to do.
Check your deflection, do the adjustment, and during the process of putting everything back together, swap out the original spring for the black spring from EPI. Total job, maybe 2hrs tops...
NYROC Tech Site
Old Apr 21, 2003 | 09:23 PM
Roofer's Avatar
Thanks guys. I have the instructions and the spring tool made. Now I just have to purchase the spring from EPI.
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
