DS won't start
Old Apr 21, 2003 | 08:04 PM
01ds650's Avatar
Default DS won't start
Guys,
Here is my situation.....
Last fall I went to the Dunes. When I first started my DS it was OK when I went to accelerate on the sand it had a miss. It wasn't like a rythmic miss. But it popped back out the carb even. Just when I was ready to head back to the truck after a couple of minutes it stopped & ran great the rest of the whole day.
Later in the fall. Same thing. Runs kinda bad at first but comes out of it. Last winter it would start but I couldn't even rev it up without it missing. I've been busy & really neglected it & not addressed the problem. Now it won't fire & just soaks the plugs. (I put new gas in it also).
The lights are bright & it cranks for awhile but could it still be the battery? For some reason that possibility sticks out.
What else should I check? Why do I feel so dumb?
Old Apr 21, 2003 | 08:07 PM
fastone21's Avatar
At
Check to see if your coils are tight. If they are loose it will do what you are experiencing. THen check to see if your fuses are good. Sound like loose coils to me.
Old Apr 21, 2003 | 09:32 PM
jiminok's Avatar
Andrew
Quick list...
check main fuse...wouldn't be your accessory fuse if the light are workin
check ground connection to frame and condition of ground wire
check connections at coils
check connection to CDI
check plug wires/boots for cracks and damage
check battery...put it on a 1.5-2amp per hour charger and then get it load tested
check valve clearance
check stator output
check rectifier
Old Apr 21, 2003 | 09:37 PM
racerx5x5's Avatar
My DS was vary hard to start , I checked the valves and thay where way to tight. I went from a 2.35 shim to a 2.10. The wierd part was I only had to do the intake.
Old Apr 21, 2003 | 09:41 PM
Eaglecollector's Avatar
Thats normal to have just the intakes get tight. Im already at the 2.00 on my intakes[img]i/expressions/face-icon-small-sad.gif[/img]
Thats OK though....That just means stage 3 is right around the corner[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 21, 2003 | 09:47 PM
racerx5x5's Avatar
I bought all the sizes it BMW. Less then 1/2 the cost.
Old Apr 21, 2003 | 10:30 PM
01ds650's Avatar
Thanks guys,
I'll try those things.
It was just odd how it seemed to get progressively worse.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
