top end
Old Apr 21, 2003 | 10:45 PM
ridered62's Avatar
Default top end
How can i increase the top end speed of my r with out losing the bottom???
Old Apr 21, 2003 | 11:13 PM
matt86250r's Avatar
Default top end
depends on how much money you want to spend!
Old Apr 21, 2003 | 11:26 PM
ridered62's Avatar
Default top end
well just give me some ideas
Old Apr 21, 2003 | 11:28 PM
trx250Rob's Avatar
Default top end
A 310 kit is a good way to start.
Old Apr 21, 2003 | 11:30 PM
ridered62's Avatar
Default top end
what all does a 310 consist of?.....a 265 what does it constist of???
Old Apr 22, 2003 | 01:15 AM
CrAcKhEaD's Avatar
Default top end
a 330 power valve would be nice, its a cylinder, piston, rings, circlips, pin and bearing, gaskets everything u need
Old Apr 22, 2003 | 10:09 AM
trapperb1's Avatar
Default top end
A really cheap way to increase top-end speed is to change counter-shaft gear or your rear sprocket.
For more top speed, go to a 12 tooth counter shaft gear or get a rear sprocket that is 3 teeth smaller.
Doing this will take just a little off the bottom end and increase your top speed.
Old Apr 22, 2003 | 09:37 PM
ridered62's Avatar
Default top end
my r is bored .40 right now...i was wanting to know what that would be...and how much farther to make it a 265 or 310
