Connecting a kill switch
Old Apr 28, 2000 | 06:53 AM
TRXbrad's Avatar
I have a 88 honda 250R. I have taken out the key switch along with the wholerun/off lhts on/off switch. I bought a pro design kill switch and I was wondering if anyone knows how to hook it up. I am unsure if the hot wire on the switch connects into the key switch or the the run/off assembly on the handlebars. If someone could e-mail me, I would be very thankfull.
Brad
Old Apr 28, 2000 | 03:07 PM
JohnR.'s Avatar
On my ATC250r I simply ran a wire from the stop/run switch wire (whichever goes to the coil)to the tether switch and then the other wire on the tether to ground. This will shut down the coil when you pull the tether cable off. To find what wire colors you are looking for just look in your Clymer manual, if you don't have one it is like the ATC/TRX 250r bible and no owner should be without one. The wiring schematics are in the back of the book.
Old Apr 29, 2000 | 12:03 AM
hondatrx300ex's Avatar
how can I wire mine and keep my key switch and my light/on/off switch?
Old Apr 29, 2000 | 01:36 AM
JohnR.'s Avatar
Look at the wiring schematic and find the wire that grounds the coil when you shut it off by the off/run switch and tap one wire from the tether switch into it and ground the other wire from the tether switch.
Old Apr 29, 2000 | 11:13 AM
Rob4092's Avatar
Will this also work when installing a Pro-Design kill switch on my Polaris Sport 400?
I cannot find the coil since it is buried somewhere under the plastic and gas tank.
I can find the handlbar mounted "Off-Run" switch wires very easily. Are you saying all I need to do is put an Ohm Meter on these two wires and see which one goes to ground when it is in the "Off" position and then hook one end of my Pro-Design killswitch on it and the other to ground?
Old Apr 29, 2000 | 12:10 PM
JohnR.'s Avatar
That should work, Brad. I am not an expert but it worked on my ATC250r.
Old Apr 30, 2000 | 03:53 PM
Rob4092's Avatar
I just finishing installing a Pro-Design Kill Switch on my Polaris as several of you suggested and it works perfectly.
Thanks for the info!
Old Apr 30, 2000 | 10:16 PM
TRXbrad's Avatar
I just finished connecting my kill switch....It was easier than I thought it would be. Thanks alot for the info.
Brad
Old Apr 30, 2000 | 10:18 PM
TRXbrad's Avatar
Brad
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
frostphase
Aug 19, 2015 07:11 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
sublime250
Jul 11, 2015 11:52 AM
