are work shocks worth the money do they help
Old Apr 28, 2000 | 09:59 AM
426ex's Avatar
[red]looking to buy some shocks but don't know which
ones to buy? any info would be great.[/red]
Old Apr 28, 2000 | 10:54 AM
JAKOOL's Avatar
The TCS shock are definitely worth the money. The TCS shocks uses the same Works shock body with different valving. It's available at CT Racing.
Old Apr 28, 2000 | 01:22 PM
TheDoc250's Avatar
I just got my TCS rear shock back and it's great, I can jump 20 ft washes with no bottoming out like when it was stock. they are definatly worth the money and alot cheeper than a ultra cross.
I do have works tripple rate fronts on my 250R.
Old Apr 28, 2000 | 01:33 PM
PAPICO's Avatar
I have a set of Works Performance shocks on my 450es. They work great under all conditions, but just latley they have developed a squeek when under hard use. been installed on the bike 1 year
Old Apr 28, 2000 | 01:56 PM
Dirtddemon's Avatar
I had works shocks on my warrior before I went red. The fronts were great but the rear really sucked. I also had a custom axis rear that in my opinion was far superior. That custom axis would soak up 8' flat bottom landings and never compress more than 1/2 way and still give a soft landing. I don't know about tcs but the customs are defininatly worth every penny.
Old Apr 28, 2000 | 06:33 PM
philzie's Avatar
I just put a set of Works triple rates on the front of my 400ex. I got the ones without cans cuz they were cheaper. $350 and delivered in Two business days.
They are the best mod I ever put on my EX. Aluminum bars are also right up there at the top.
Old Apr 28, 2000 | 08:13 PM
hondatrx300ex's Avatar
I put works dual rates without the reserviors on my 300ex. the dual rates springs make it ride real smooth. I haven't been able to jump it since I'm not totally back to normal from my broken leg. but from what I can feel once you use up the top spring it gets STIFF which is gonna be good for jumping. one thing you might wanna know about the Works is they don't have rubber bumpers inside of them so anytime your front wheels come off the ground you can feel a very slight pop which is the shock at the end of its travel. this isn't hurting anything and really doesn't bother you. if you would like to know anything else about my works shocks feel free to ask. later
hugemoth
Jul 20, 2020 03:28 AM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
