200x runs for 5 secs. then dies
Old Apr 24, 2003 | 03:46 PM
Michiganredneck's Avatar
Default 200x runs for 5 secs. then dies
I could use a little help. I have managed to get this thing to run, but it cuts out after about five seconds. At this point, I have replaced the pulse generator, K&N filter, spark plug, fuel line, had the coil tested, and cleaned the carburetor. When I drain the fuel bowl, it will start again and run for another five seconds, but I can kick til the cows come home and it won't do anything until I drain it again. Do I have a jetting problem, or something completely different? Thanks for your help.
Old Apr 24, 2003 | 03:51 PM
Honduki's Avatar
If you pull the plug after it stalls is it wet? If it is you have a carb problem of some sort.
Old Apr 24, 2003 | 05:09 PM
twitchell's Avatar
my friends warrior did that and the carb was full of trash.
Old Apr 24, 2003 | 07:49 PM
mojave300ex's Avatar
Your fuel valve could be pluged up and not flowing correctly.. Carb could have trash in it but usually that just makes them run terrible all the time, not after 5 min. Fuel filter clogged?? And.. is the choke working? Good Luck.
Old Apr 24, 2003 | 08:09 PM
Ozarkrider03's Avatar
Honda reliability lol
Old Apr 24, 2003 | 09:45 PM
I took the carb apart and soaked the jets in carb cleaner for a couple of hours, put it all back together and it started right up. Not bad for a beat up 20 year old trike that hasn't been run in two years. I'll take that kind of reliability. It actually ran pretty strong. I was somewhat impressed for a little 200x. Thanks for all your help.
whitty
67
Feb 24, 2021 02:52 PM
Raccar1
Jun 18, 2015 02:17 AM
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
garyt1975
Jun 5, 2015 08:53 AM
bigmanm
Jun 28, 2000 10:34 PM
