Lights
Old Apr 26, 2003 | 12:34 PM
GIBS's Avatar
Default Lights
Hello Fellow Riders,
I have a Honda 200s 3-Wheeler and the head light and tail light burns out as soon as I put a new one in. I have added extra ground wires and checked everything I can think of. Can anyone give me any suggestions on what to check out next? Anything will be greatly appreciated!
THANKS![img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img]
Old May 5, 2003 | 08:47 PM
HondaATC110RULES's Avatar
Default Lights
I was thinkin it might have too big or too high of a fuse, since the fuse should go before the headlight.
Old May 7, 2003 | 01:44 PM
lisnup's Avatar
Default Lights
Check fues size, but I am leaning to a voltage issue. Chech the voltage and report back.
Old May 31, 2003 | 09:38 PM
robh's Avatar
Default Lights
Are you running a battery?? if so check to see what the voltage is on the battery with the bike off and with it running. It should be around 12 volts not running and 12 -13 at idle and then check what it is with the idle up bout half throtle. It sounds like you have an over voltage prob to me...Rob
Old Sep 11, 2003 | 07:57 PM
PalmSpringsPolaris's Avatar
Default Lights
Did you solve this problem? I just got a 85 ATC250R, when the peepboy and bought a replacemnet headlight bulb (tail is also out) and hooked it up started the engine and I works, YES, but then when I reved the engine the light got brighter then POP, blown. I has the rear fender off and noticed that one of the 2 wires connected the the voltage regulator was disconnected. The voltage regulator is located next to the frame unter the rear fender near the air box on the 85 250R. If the voltage regulator was disconnnected or "screwed" up it would explain the light getting brighter when the engine is reved........
Just a thought, will get a new buld tonight and let you know...
Old Sep 12, 2003 | 06:45 PM
chadincolo's Avatar
Default Lights
99% sure it's your voltage regulator. Replace it and I'll bet your bulb issue goes away.
Old Sep 12, 2003 | 07:12 PM
Default Lights
My problem was because the voltage regulator was disconnected. also the connection terminals were corroded so I replaced them also. Works great now...
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
