Pop after shut off
Old Apr 27, 2003 | 01:10 PM
Guest
Guest
Posts: n/a
Default Pop after shut off
Well I finally got all my stuff on the Raptor. Now, it runs excellent and has more power than I imagined but anyway after I shut it off there is a soft pop, not a backfire about a second after I shut it off. Suggestions? Also, I had a little problem tensioning the chain, well I broke on of the bolts and only about 1 and 1/2 threads are showing! Is there any possible ways that I can get that bolt out? Also, were there more than 1 nut I was supposed to loosen to before going to those 2 bolts to adjust the chain? It just seemed abnormally hard and I thought I was going to break a bolt while I was doing it, speak of the devil, I slipped once and the bolt came with me, any help is greatly appreciated,
Patrick
Old Apr 27, 2003 | 01:56 PM
RepTaR660r's Avatar
The pop is probably excess fuel that didn't get burnt off.. Quadman's bike shot a flame out the end after he killed it and it burnt all the hair off my arm... There are 2 nuts 17mm i think, that u have to loosen before adjusting the chain. If you were trying to take slack outta the chain i would left the 2 small bolts alone and just pulled the carrier back towards you, then tightend the 2 small bolts down. If you were trying to get more slack i would backed the 2 bolts out a bit then kicked the carrier up 2 them.
Old Apr 27, 2003 | 02:11 PM
sixsixT's Avatar
Mine makes that pop too. I don't think it's anything to worry about.
Sounds like you didn't loosen the carrier bolts when you adjusted the chain. Try making a slot in the broken off bolt with a hacksaw to screw it out with a screw driver. Loosen your carrier bolts before you try to unscrew it to take the pressure off.
Old Apr 27, 2003 | 03:01 PM
Guest
Guest
Posts: n/a
thanks for the help on the pop guys. Well I did take the nuts off of those 2 bolts and I looked for carrier bolts, there was only 1 on the old warrior I had but I couldnt find any ob the raptor, , thanks for the idea on getting the bolt out too, you guys are great, any furtehr help appreciated,
Patrick
Old Apr 27, 2003 | 03:07 PM
sixsixT's Avatar
There are two 17mm nuts behind the brake rotor that you have to loosen.
lonerider856
Oct 13, 2023 03:45 PM
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
Matt123
Sep 29, 2015 01:29 AM
