Adjusting rear brake.
Old Apr 28, 2003 | 09:13 AM
02BAJA's Avatar
Default Adjusting rear brake.
How do you do it? I have to puch the pedal a good 2 inches before it grabs.
Old Apr 28, 2003 | 10:52 AM
fastone21's Avatar
sound like you needs pads not an adjhustment.
Old Apr 28, 2003 | 12:21 PM
DSDuneCrazy's Avatar
Even if you need pads, you shouldn't have to press the brake that far. Hydraulic brakes should be auto adusting for the most part. Check your pads, replace them if needed and see how it goes from there.
Old Apr 28, 2003 | 07:20 PM
ThePunisher's Avatar
You probably need to bleed the brakes, mine is doing the same thing.
Old Apr 28, 2003 | 07:26 PM
racerx5x5's Avatar
Dennis Kirk Moose pads part#19-3861 $34.95. Just got some, will see how thay work.
Old Apr 28, 2003 | 08:00 PM
also, make sure your brake fluid is not low, as your brakes wear more fluid will be reqired to fill the lines and caliper when braking. If the fluid is too low, it can suck air into the line after you release the brakes.
So other than watching your fluid level, and keeping an eye on the pads for excessive wear, there is no adjustment needed. Angry is right, after you replace the pads, you will probably have to bleed the lines.
-Tom
Old Apr 28, 2003 | 08:34 PM
Hightower's Avatar
replacing pads should never cause the need to bleed. they would only need blead if lines have ever been loosened, or fluid level was ever allowed to get to low.
Old Apr 28, 2003 | 08:41 PM
that's what I was trying to say, if the fluid goes to low. (because of break wear and lack of attention to fluid level).
STLyamwar
Jul 25, 2020 04:44 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
WilliamBos
Jul 13, 2015 02:11 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
