2001 400EX NO RUN :(
Old May 1, 2003 | 06:42 PM
RIjon's Avatar
Default NO RUN :(
Damn thing was running yesturday
Cleaned it all up , put rear brake pads on it
Will NOT start [img]i/expressions/face-icon-small-mad.gif[/img]
I Get plenty of fuel but it seems like it is NOT getting spark
I removed the plug and it was soaked (obviously)
Checked the gap and stuck it into the WIRE .....Grounded the plug and cranked the Engine ....NOTHING , no spark
On a Car I know that means that the ignition modual,coil,etc ..is bad
Does this apply to Quads as well ??
Ideas , Advice, Common Problem?
HELP!
I Tried POP starting it ..but it Still would not fire
Old May 1, 2003 | 06:53 PM
RIjon's Avatar
Default 2001 400EX NO RUN :(
Hmmmm
I wonder ....
Old May 1, 2003 | 07:04 PM
RacinJason's Avatar
If the plug cap was soaked dry it out with compressed air and try it again.
If you have a test light put it on the inlet of the coil(primary) and turn the quad over...is your test light flashing?
Old May 1, 2003 | 07:54 PM
RIjon's Avatar
You guys are the SHIZZLE MO FIZZLE
I did a search (imagine that) and Found that ppl had to remove the plug and COOK it with a torch [img]i/expressions/face-icon-small-shocked.gif[/img]
Sure enuff.... Damn thing Started right up [img]i/expressions/face-icon-small-happy.gif[/img]
Now that is just weird
Thanks again , This site Rocks
Old May 1, 2003 | 10:03 PM
RacinJason's Avatar
BRAAAAAP
that what we like to hear...
knew it was an easy fix just by the title
2001 400ex
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
