What mods to start with on my new 03 Prairie 650?
Old May 6, 2003 | 01:55 PM
GraveLayer's Avatar
Default What mods to start with on my new 03 Prairie 650?
I'm thinking I need a new air filter and Diamond G snorkel.
But what filter and WHERE can I order it online?
Next I was thinking about doing Nyroc's Exhaust Mod but then wouldn't I have to re-jet? If so to what?
Then I was thinking of putting in this Black Secondary Spring
http://www.erlandsonperformance.com/...ode=secsprikaw
Thoughts on what I should start with that WON'T void my warranty????
THNAKS!
Old May 6, 2003 | 02:02 PM
MURPH1's Avatar
Put some new shoes on it cause the stockers suck
Old May 6, 2003 | 02:08 PM
GraveLayer's Avatar
I won't do that for a while. Way to much $$ to be spending after all its NEW! [img]i/expressions/face-icon-small-smile.gif[/img]
I've been through plenty of mud, trails and pavement on the 80 miles I have on and so far I've had no problems with the tires.
Old May 6, 2003 | 02:09 PM
Lightman's Avatar
The first thing you should do to your p650 is the black spring. Do it now, do not wait for your belt to slowly wear away! This is a $25 mod that will save you a whole lot more.
New tires is a must, I ebay-ed my stockers actually.
I really would also recommend upgrading the skid plates, I just installed the ricochet plate, and it's awesome. The stock plate crunched like tinfoil when I hit a few stumps/rocks.
Old May 6, 2003 | 02:25 PM
GraveLayer's Avatar
What did you get on ebay? (I have a 70+ rating) On the tires your saying the stock are not good in the mud I assume? I will mud but trail ride much, much more.
I have the spring on the way but am a little "afraid" to do the job. Nyroc's site is the only reason I even ordered the thing. Have you done the black spring mod? Also I don't know about making the spring tool....can I buy one? Ouch I see EPI has one for $80!
Old May 6, 2003 | 05:38 PM
tampavii's Avatar
Change the tires I love my 26 inch Mudrunner .Yesterday I installed Progressive front spring .WOW what a difference.
Next is the spring I have to order the black spring .
Just not sure if i can install it
Old May 6, 2003 | 05:44 PM
jwkawi's Avatar
i thought my stock tires were going to be ok until i punctured the sidewall in two spots on a not so hairy trail. definitely upgrade the tires. dunflops suck @$$. rides like a different machine with the new shoes. check my pics for a look.
Old May 6, 2003 | 07:27 PM
Lightman's Avatar
I wasn't sure about the spring so my dealer installed it and set the belt deflection. Definitely get a tire with 6-ply protection, not the 2ply stockers. Everyone seems to puncture them.
I believe I sold my stock set for $100 or so, with 300 miles on them. The holeshot atr's were a night and day difference for trail riding. Dont bother taking the stockers in deep mud.
Old May 7, 2003 | 07:33 AM
yellow68601's Avatar
pro circuit pipe, go threw www.westymotorsports.com over $100 off retail, jet kit go threw www.rockymountainatv.com 50% cheaper than any where else and for the spring compressor dont waist your money. if you have a buddy and you know someone that has an olympic weight set, use a 45lb weight, the hole in it is perfect. just put it over the top have a buddy push dowwn, take the retaining clip out, put in the new spring, push down againput the clip back in and thats that
Old May 7, 2003 | 08:00 AM
trx450's Avatar
I sprung for new tires after I almost got hurt(as in hit a tree) for the second time. Do the tires, Do the black spring. Then, when your wallet re-fills, do the Progressive frt. spring kit.
BTW-- Nyroc's "650 knowledge base" has a ton of tips, how-tos. He shows you how to make a simple, $5.00 clutch spring compressor.
