What mods to start with on my new 03 Prairie 650?
Old May 7, 2003 | 03:18 PM
  #21
GraveLayer's Avatar
Default What mods to start with on my new 03 Prairie 650?
MDG,
Thanks for the ton of great info!! I'll put on about 200 miles in Iron River WI in a couple of weeks. I'll know after that if the stock tires will work for me for a while! Nice to know that 26" mudrunners fit on the stock rims!
Old May 7, 2003 | 06:04 PM
  #22
tampavii's Avatar
Progressive spring makes turning and jumping alot easier. Plus you can turn on a dime at fast speed.alot less front end roll
I got rid of the stock dunflops after my first ride almost filped it over on trails .
If I you have just few $$ to spend get NEW TIRES first. Before you hurt yourself or get flat.Yes mudrunner will fit stock rims I used stock rims. But had hard time getting someone to mount them Spent $80.00 to mount. Now wish someone would make after market plastic
One questions
If I install the Diamond G snokle do you have to re jet carb. If not then what can I expect with this mod plus installing black spring .I should have black spring next week. How just have to fine place in NJ with NO COP to ride in peace.
Old May 7, 2003 | 06:46 PM
  #23
RedneckLeatherneck's Avatar
I just purchased a new 2003 Prairie 650 and i would like to install magnetic drain plugs on the engine and front & rear diffs. Any help would be appreciated...........Top Notch Forum
Old May 7, 2003 | 10:33 PM
  #24
kawirob's Avatar
Hi GUY'S:
Tires are a must. I have 26" Kenda Bear Claws on mine and they are awesome. The are probably one of the best over-all tires out there. Believe me I've done my research and got a ton of opinions. The black-spring is a cheap mod that you should do to save your belt life. Also in terms of performance...get a "Modulator Box" for your beast. It takes 5 minutes to install and the bike turns into a savage weapon instantly! The mod box advances timing right on the bottom end , and gives us back some of the power Kawi hid from us , when they de-tuned the bike , before they were released. The box will make you P650 wheelie like sport quad from a dead stop...in high range or low...DOWNHILL!!! The bike turns into a holeshot freak! The tranformation is almost overwhelming and WELL WORTH IT!!! You will probably lose some top end...but there are also top end modules becoming available that add 15kph (9mph) to the top speed. The top end loss if any ( I haven't tested mine since adding the mod ) is minimal and not important to me. There are few places locally that I can let her fly. Have fun!
PS: do a search on "Modulator box", "Performance Module", and "accelleration Module" and you will find lots of info.
ROB
Old May 8, 2003 | 10:12 AM
  #25
GraveLayer's Avatar
kawirob,
I did a search on all three of your search ideas and ALL came up BLANK.
How about a link or the place you got yours from???
Well I only searched this forum but I may have come up with something on a google search! [img]i/expressions/face-icon-small-smile.gif[/img]
kwackermann
Jun 24, 2015 10:18 AM
Nelson
Jun 22, 2015 03:51 AM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
1000gade
May 25, 2015 10:48 AM
