Oil Change
Old May 1, 2000 | 05:08 PM
snowshark's Avatar
I picked up the quads from their 20 hour check up & the dealer informed me that the oil should be changed ever 2-3 times you ride? This seems a bit excessive. I was thinking about every 100 miles or so.
How often do you change you oil in your ATV?
Old May 1, 2000 | 06:30 PM
JRM's Avatar
JRM
Depend on how far you ride, I have to change mine after ever ride because I often blow 400 miles a weekend but if you just put around now and then, the twice a year works too, just dont go beond 500 miles on the same oil. Joe
Old May 1, 2000 | 07:11 PM
snowshark's Avatar
JRM,
I usually ride 20-30 miles a day. How do you ride 400 miles in a weekend, do you sleep on your quad?
Old May 1, 2000 | 07:18 PM
HHonda's Avatar
You only need to change the oil every 20 hours but if the oil is real black befor that i would change it and dont forget to change the oil filter every time
Old May 1, 2000 | 07:24 PM
thomas's Avatar
i used to change mine every ride but i blew it up so i don't anymore but anyways if you change the oil and filter often even though it sounds expensive it will make your quad last longer and run better.
Old May 1, 2000 | 11:02 PM
drlaney's Avatar
According to Greg Hall (Tech Connection), you should change your oil after every five tanks of gas and clean the air filter after every ten.
Also, be sure not to fall for the common ploy from unethical dealers who claim that your warranty is void unless you pay them to change your oil. Consumer groups have taken this issue to court and won in your behalf. All you must do is keep a written record of the work having been done at the specified intervals.
Also, I would report any dealer who pulls such a trick to your local Better Business Bureau.
Old May 2, 2000 | 12:11 AM
b(250rman)'s Avatar
we change the oil and oil filter and we clean our air filter in our 300ex about every 6 months it isn't ridden much but when it is. It is riden hard I check it every time before I ride it (about 2 times a month)and hasn't been black yet.
Old May 3, 2000 | 01:00 PM
tempest's Avatar
Is there any reason why a person shouldn't follow the schedule in the owner's manual? I believe it suggests changing the oil every 600 miles.
Old May 3, 2000 | 03:26 PM
Motorhead's Avatar
I think the owners manuals assume you won't be riding the quad very hard most of the time, in which case 600 miles probly wouldn't be excessive (especially compared to 3000 miles in a car). However many people don't even ride 600 miles in a year, and the oil shouldn't sit there that long, it should be changed a minimum of twice a year. Probly the reason quads need changed more often than a car is because they run in dirty environments and run hotter (being air cooled), thus the oil breaks down faster. Also keep in mind that (in theory) synthetic oils last much longer than conventional oils, so you could probably go twice as long before an oil change.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
