yamaha blaster oil injection
Old May 11, 2003 | 06:33 PM
crispy's Avatar
Default yamaha blaster oil injection
hello, does anybody know if getting a blaster block off kit is worth it. Does it really save your top end in the long run if you mix your own oil and gas??
many thanks
Crispy
Old Jul 26, 2003 | 10:45 PM
supersampson's Avatar
I have never had a problem with the oil injection...I would just leave it
Old Jul 28, 2003 | 01:49 PM
02blastr's Avatar
Check out this post. It might answer your questions. http://forums.atvconnection.com/mess...did/349225.cfm
Old Aug 26, 2003 | 11:53 PM
blaster2002004's Avatar
i've heard of the oil injection failing so is it a wise thing to get a block off kit.
Old Aug 27, 2003 | 11:27 PM
crispy's Avatar
blaster2002004- how does the power of the procircuit exhuast set up compare with the power of the stock machine
Old Aug 28, 2003 | 12:31 AM
raptorblasterracer's Avatar
GET THE BLOCK OFF GET THE BLOCK OFF GET THE BLOCK OFF
UR RUNNING UR BLASTER WIT THAT DUMB A$$ OIL INJECTIOR
STOP NOW
u don't need to get the block off..helps wit starting a little
premix the gass the pump tends to fail and straight gass goes into a 2 stroke [img]i/expressions/face-icon-small-sad.gif[/img]
i don't wanna hear about another blaster seizing up due to that D#%^ thing
just get a ratio cup and premix the gass and ur be protecting yourself froma costly repair
Old Aug 28, 2003 | 05:08 AM
raptor8's Avatar
I've never had an oil pump problem, and i've owned several yams over the years. I'm not worried about it. I DO run Blendzall in it cuz it's a little thicker than the yamalube....there was some speculation that the yamalube was so thin it was getting air bubbles in it in the feed hose... it wouldnt take much oil starvation to damage it.
Honestly I havent had a problem. and since i have a raptor too, I carry only one gas can. nice [img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 29, 2003 | 09:35 PM
ur lucky!
Old Sep 14, 2003 | 01:50 AM
schewin's Avatar
I would take it off..If it fails, your screwed. the engine will seize and have fun w/ that. I also took it off mine because some of the racing oils you cant put in the oil injection systems and weight..not like the blaster needs to take and pounds off though its extremely light.. I also like mixing my oil cause im a more do it yourself kinda guy..
2quiker
Mar 22, 2022 08:36 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
