Arctic Cat Side By Sides Talk about all the Arctic Cats, Sport and Utility
Need help with secondary clutch please
Old Oct 10, 2019 | 10:53 PM
neub7's Avatar
Default Need help with secondary clutch please
I just bought a 2008 Prowler 650 H1. Rode it about 20 miles and the belt absolutely exploded! Long story short, while replacing the belt, I spread the secondary with the cover bolt and didn't take it out before I put the secondary back on. I tried to remove the bolt after I tightened the nut and it snapped off still stuck in the spreader hole. I have no idea what to do. Any help or suggestions would help greatly. Thanks.
Old Oct 12, 2019 | 02:48 PM
sr.ruedas's Avatar
You are going to have to remove the broken bolt. You will need to center-punch and drill it with a cobalt bit just smaller than the bolt diameter. Then, you will need to use an "easy-out" tool to insert into the hole and turn counter-clockwise. If you have not done this before, check on Utube or pay a mechanic.
Nordern
Oct 16, 2009 07:46 AM
MWMKX250
Oct 30, 2005 07:17 AM
trailblazermudrunner
Aug 27, 2005 10:43 PM
alwaysride
Aug 11, 2005 09:49 PM
prairievenom
May 3, 2003 11:40 PM
