winch
Old Jun 21, 2003 | 08:22 PM
liquidplumber's Avatar
Default winch
Can somebody please tell me the easiest way to wire warn winch. I want to do it direct no solenoid and just a simple switch.
thank you
Old Jun 21, 2003 | 09:50 PM
jwoodsman's Avatar
Default winch
did you get the winch from your Ac dealer , If so they come with the direct plug in to your fuse box with the switch on the left grip .
Old Jun 21, 2003 | 10:03 PM
jwoodsman's Avatar
Default winch
First thing find a power sours only with the key on, normally it's a white wire or a red wire ,Black is ground you can place that wire directly on the frame or the battery neg side ,that will work .
Old Jun 21, 2003 | 10:11 PM
Default winch
What I need to know is which wire to put on the battery #1 or #2 and what to do with the other wire I can probably figure out the switch
for myself thanks in advance
Old Jun 21, 2003 | 10:31 PM
jwoodsman's Avatar
Default winch
in my book #1 is the ground #2 is blue power /solenoid try this
I have the manuel it came with
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
