Arctic Cat 500I Weak points?
Old Jul 12, 2003 | 09:15 PM
WearyWonderer's Avatar
Default Arctic Cat 500I Weak points?
Does the Arctic Cat 500I have a weak point?
Is it the axles?
Just so I know, what is the cost of a replacment axle, can I repair it in the field, and is it interchangable left to right, front to rear?
If there is another weak area for the Cat, could you point it out ?
Would you also let me know the cost of those repairs?
Thanks....
Old Jul 13, 2003 | 05:35 PM
Bigcat's Avatar
Axles are all the same but the 04 's are stronger. IO have an 02 500i, no problems yet 850 miles.
Old Jul 13, 2003 | 09:48 PM
CatsMeow's Avatar
generally speaking, a cv axle cost about $150. its a 20 minute job to replace. if you have tools and diff fluid you could do it anywhere. left to right is the same axle, front to back, not sure. weak point? for durability its probly the axles for 03. i dont think its too much an issue anymore.
Old Jul 13, 2003 | 10:02 PM
cueball89's Avatar
Where do you get axels for the cats? Which place is cheapest? A friend has 1 and he needs a new 1.
thanks
Old Jul 13, 2003 | 10:11 PM
CatsMeow's Avatar
if your dealer is not available, try www.alpha-sports.com or www.brownsleisureworld.com
Old Jul 13, 2003 | 10:23 PM
Hey while I got you guys, I sat on a Cat the other day.. The seat needs help.. Is there a way to modify the seat? In general make it flatter in the front so you don’t feel like you have to climb back up all the time... Make it function more like the Kawasaki Prairie 360?
Thanks...
Old Jul 13, 2003 | 10:38 PM
CatsMeow's Avatar
dont know of any seat mods. just scoot back, the seat's a mile long dude.
Old Jul 13, 2003 | 10:54 PM
Well honestly I like the option of sitting forward and back. It keeps my back and knees from aching.. Mostly my Knees.....
Old Jul 15, 2003 | 02:22 AM
JohnO's Avatar
From what I've heard, the axle problem seems to be a bad batch of axles that got onto some 03 models. I have an 02 500i, never a problem with the axles. I understand that putting on a lift kit can cause CV joint problems, but with all the ground clearance the Cat already has, that seems rather unnecessary.
Only problem I've had in over 600 miles is the 1st gear lamp going out. N and 2-5 still light up, so it's probably a burned out bulb. Pretty trivial. Otherwise, it's been put gas in and go. Excellent machine, has been a real workhorse on the farm, and plenty of fun, too.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Customer Service #1
May 15, 2020 08:46 AM
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
