gear indicator light out
Old Jul 25, 2003 | 01:07 AM
New400i's Avatar
Default gear indicator light out
last ride the gear indicator worked ok. this time it don't. any ideas?
Old Jul 25, 2003 | 09:45 AM
tricat's Avatar
Check the connection under the front plastic. This can work loose.
Old Jul 25, 2003 | 10:12 AM
sxr6's Avatar
Did you install a winch yourself?? If you don't add the extra little wire that comes with Cat winches the gear indicator light will burn out.
Old Jul 26, 2003 | 01:07 AM
JohnO's Avatar
Which wire is that? I put a winch on last summer, and the only extra wire I could find was the one to supply power to the solenoid.
Old Jul 26, 2003 | 11:34 PM
New400i's Avatar
I did mount an aftermkt warn winch myself on a.c. mount, I did not get an extra wire apparently. Should I pursue fixing it( no big deal other than losing temp light). If I leave it will anyhting else burn out? I will check the otheer possible lose wire. Thanks all.
skinnyr6
Aug 25, 2023 02:18 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
