Like to play in water beware!
Old May 22, 2000 | 08:04 PM
sxr6's Avatar
Just discovered this weekend after drowning both 500 & a 300 Cat that Cat has run 2 carb vent hoses only couple inches above carb. Guess what, that's right, that muddy water you just spun up now runs right into the float bowl. Fortunatly it's easy to run them up to carb intake area to allow those quick dips you don't plan on.
Old May 22, 2000 | 08:56 PM
Tree Farmer's Avatar
I don't think those hoses lead to the float bowl; rather, I bet they are vent hoses for the vacuum-operated slide cylinder.
Raising the hoses to the air intake may be a good idea; also, you can extend the hoses, creating a U-shaped bend in them at the top and dropping the hoses back down, preventing sucking water into the carb assembly when playing submarine. With a U-tube arrangement as described, and airbox air intake above the water line, a carb will work fine when totally submerged. When you "surface," the small amount of residual water in the vent tubes drains out the bottom.
Tree Farmer
Old May 23, 2000 | 09:53 AM
sxr6's Avatar
You may be right tree farmer, but I know the mud goes right into the float bowl.
Customer Service #1
May 15, 2020 08:46 AM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
