bump steer 500's
Old May 27, 2000 | 10:09 AM
sxr6's Avatar
I reversed the outer steering joint on buddies 99 500, after good long ride he tells me it handles MUCH better plus maybe is also little easier to steer. Just thought you might like to know, good riding.
Old May 27, 2000 | 02:31 PM
BONER's Avatar
What do you mean you reversed it??
Old May 29, 2000 | 09:24 AM
sxr6's Avatar
You unbolt the outer steering ball joint where it feeds down through steering arm & feed it UP through arm, now your A-arms & steering rod is paralel. Don't forget to realign your wheels. If you want to see what bump steer is, push front of your machine up & down while watching the tires.
Old May 29, 2000 | 02:11 PM
BONER's Avatar
Thanks
Old Jun 11, 2000 | 06:40 AM
BONER's Avatar
Any one else gonna try this?
Old Jun 12, 2000 | 10:36 AM
sxr6's Avatar
Boner, when you did this did you notice it easier to steer as well?
Old Jun 12, 2000 | 10:12 PM
BONER's Avatar
When I get my cat back from the shop I will do it.
Untill then I have the same question.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
