For those thinking of a new 650!
Old Sep 14, 2003 | 06:22 PM
CRUNCHMAN's Avatar
Default For those thinking of a new 650!
I saw where someone asked about a Naber module. I have an 03 650 prairie. The modules, there are several produced, are used to trick the cdi. Since the 650 shared the same engine, the modules will most likely work on the ACs. Diamond G racing offers what I would consider the best module, it is called the holeshot. I gives full timing advance to a certain RPM then returns to stock. These engines are neutered from the factory with alot of timing retard! Diamond G has been working on, and should be about to release another module called the unlimiter which keeps full timing advance to the rev limiter.
This along with the holeshot will greatly improve acceleration. Top speed should be over 70 mph fairly easy with both. With just the holeshot, if I start from a standstill it will stand straight up, and that is with 28" tires. For anyone interested in more info, check the Kawasaki forum.
Old Sep 14, 2003 | 07:48 PM
luvthemud's Avatar
sounds cool, thanks for the info
Old Sep 18, 2003 | 02:56 AM
CatKrazy's Avatar
Im guessing they are regulated..otherwise the rod or piston would go. Do you know what the specs are as far as degree of advance?
thanks
Old Sep 19, 2003 | 05:17 AM
CRUNCHMAN's Avatar
I can't recall the exact numbers. However, I believe stock the timing retards somewhere around 28 degrees! It is substantial. My reason for starting this thread is to provide info that the 650 cat will have alot of potential for hop ups, since it has the prairie motor. There are also quite a few clutch springs to choose from. I am currently waiting on the unlimiter module for my 03 prairie. If it makes the difference the holeshot module does then it will be awesome for a utility. You should be able to outrun the likes of a 400ex!
Old Sep 19, 2003 | 11:47 AM
CatKrazy's Avatar
WOW
THAT WOULD BE AWESOME. I could not imagine going that fast on a 700 lb utility. LEts us now the outcome.
COFatboy
May 2, 2020 12:06 AM
raceware
Jul 30, 2015 06:59 AM
ghost civic
Jul 15, 2015 10:48 PM
coldnorthpol
Jul 14, 2015 11:22 PM
