OxLite Brush Guards
I finally received my Dennis Kirk Catalog & tried today to order the Oxlite brush guards for my 500 Auto. They said the parts are on backorder until the end of July. Is this normal? The price seemed okay ($42.99), the lady on the phone was very helpful & nice but I don't want to wait all summer. They didn't even have a part number for the Cycle Country guards to fit my ATV. My AC dealer wanted over $90.00 for a pair of stick guards. Any other ideas?? I'm thinking about fabbing up a pair in my garage, I've got a welder, just need some kind of template or someone with imagination. Lance
try looking at cabelas' stick stoppers. i do not have a current catalog but the number is 1-800-237-4444. they should be able to ship you the right ones. stick stoppers are pretty much the same thing as cycle country and ox-lite guards. they are about $45 plus shipping.
www.ROCKYMOUNTAINATV.com lists the Oxlites for $34.99. I don't have any idea what they have in stock but it might be worth a try. Good luck.
Catlance, I'm glad to have been able to help. I think you'll be happy with your service from Rocky Mountain. I have the luxury of living about 35 minutes away from their outlet store and I've been pleased with them the few times I've dealt with them. I'm going to get some of the Oxlites for my machine here in the next week or so. Good luck with the installation process, everything I've read and heard about the Oxlites has been positive.
So I'm installing my brushguards & as is par for the course with me, I'm taking an easy job & making it difficult. Ox-lite stresses that you do an extreme turn test to make sure nothing rubs when the suspension is flexed. I had the bike on a lift while installing, so the suspension was at full droop---when the tires are turned to full lock, the front of the Rim & Tire rub the guard. On the right side I was able to use a special tool (Crescent wrench) to bend the guard enough to clear, but on the left side, because of where the factory mount for guards is welded to the A-arm, the guard not only rubs the rim & tire but also hits the brake caliper at full lock. I either need to re-drill the holes on the guard to position it better or do some serious bending of the guard to clear the components. I am not sure how often I will have the bike turned to full lock when the suspension is at full droop but just in case, I don't want to tear something up. I am also thinking about reversing the U-bolts to go up thru the guard & using a steel bracket on top of the A-arm to secure the guards in order to keep the nuts & threads from hanging up or getting bashed. Good thing it is 100 degrees outside & I don't feel like riding until it cools off a little. Lance
If you have excess hangover on the sides, use a grinder to just grind down the sides a bit. It might take a while, but a guy I know had to do that on his Grizzly. As far as the bolts go, I just got mine how I wanted them and hacksawed the ends off. Never a problem and I have been in the rocks quite a bit. The Oxlites are one of the best things I have put on my 500.
hmmmm, very suprised to hear your guards rub. You sure you have them positioned toward the center of the machine as far as they will go? I put mine on and had no rubbing any where at all. Seems like a perfect fit. And then like Andy said, cut off the extra threads with a hack saw and your all set!
