Do your Cats sit perfectly level???
Hey Guys,
I think I figured out the majority of my problem. I think I have a leak in the left front tire. I had checked the tires, and they were OK. The next time I saw them, it looked off level. I checked the air and there was only 1.5 lb pressure in the left front. The other front was 4.5 and the rears were 3.5 as specified. I aired the tire up and that helped alot. One final question. What would you recommend to fix the leak, and what pressures do you guys use?? I set them at 4.5 and 3.5 as specified in the manual.
Thanks for all the suggestions, I'm still gonna measure everything as soon as the weather clears a little. Any suggestions??
REVHIGH !!!
[img]i/expressions/face-icon-small-wink.gif[/img]The left side of my 2000 500 cat is 3/4" lower, and it not tire pressure. Doesn't bother me except when I'm plowing snow, the left side of the plow touches the ground first. By the way I measured it back when it did bother me.
Springs could be a culprit for a lot of not sitting level. It's hard to make them exactly the same - the Audi TT throws out half of them at the plant because they need the car to sit perfect because of the tight wheel well clearances. I image atv springs will have as much or more variation.
