Restictive Cat 650 Snorkel
Old Mar 3, 2004 | 01:33 AM
bfb750BF's Avatar
Default Restictive Cat 650 Snorkel
I am going to do the increase intake of the Stock Cat 650 1 5/8" Snorkel to the home made 2" system. I know some of U have already done this quick fix for getting in more air & getting more HP= more mid-range & top end power. On my P650s I had the DG Snorkel, a Twin-Air filter & was using jets of 132F/138R for the elevations that I ride at, the results were well worth the snorkel mod.
Being that I will be increasing the air intake by 21% over stock on the Cat, should I just stay at 138 jets for both carbs or jet the same as I was with my Prairie 650s?
Old Mar 3, 2004 | 10:02 AM
Wires's Avatar
I'd start with the stock Prairie sizes. That seemed to work good for me.
Old Mar 4, 2004 | 07:13 PM
LittleBoy's Avatar
bfb650BEARCAT is right, the Kawasaki 650 needs more air. The engineers at Kawasaki admitted it themselfs. More clean air will be good and it will help!
Old Mar 4, 2004 | 10:21 PM
greencat650's Avatar
Will the DG Snorkel for the Prairie work on the 650 cat?
there was also talk of a NAPA hose # ?
Old Mar 5, 2004 | 12:26 AM
bfb750BF's Avatar
NO, The DG P650/700s snorkels will not work.
I will use a 2" PVC elbow attached to the air-cleaner inlet, I then will make another connection to route the mod snorkel to recieve the incoming air from outside of the air-cleaner area. You want to bring in cold air (outside air) you do not want to suck in warm/hot air from the engine area. Cold air makes HP. TTTM has some pics on the Mod for the home made snorkel for the Cat 650 on HighLifters site, look for the 650 intake snorkel post.
Old Mar 5, 2004 | 12:34 AM
Thanks thats the info I've been looking for!
Customer Service #1
May 15, 2020 08:46 AM
Steeldon
Sep 9, 2015 09:38 AM
switzomatic
Aug 24, 2015 12:57 PM
Ean
Aug 20, 2015 07:13 AM
Cantbuytime
Aug 17, 2015 06:33 PM
