Belt Sensor Problems w/2004 650 V Twin
Old Mar 25, 2004 | 01:15 PM
YAnn1958's Avatar
Default Belt Sensor Problems w/2004 650 V Twin
I'm not sure if anyone knows about the problems you can run into with the belt sensor freaking out on you. It will cause your belt light to flash and you won't be able to go any faster than a maximum of 13 mph. There is a little part that you can get from the dealer that you plug in to two plugs above the Transmission Belt Housing. The part comes with complete instructions. I was told that Artic Cat is aware of the problem and it is the only work around they can come up with.
Old Mar 25, 2004 | 01:18 PM
turbocoupe's Avatar
here is the AC part number for the reset plug AC 0486-161 it comes with a tag on it and explains how to do the procedure
Old Mar 25, 2004 | 01:24 PM
peteyz24's Avatar
i believe YAnn1958 is talking about the fix plug that they have issued for it. I read about it on here a while back, dont know the part number though.
Old Mar 25, 2004 | 01:25 PM
YAnn1958's Avatar
Oh I got the part and my dealer was aware of it. It was just the 3 hour ride out of the woods @ 10 mph....Just wanted people to be aware and not get stuck in the woods like I did. But thanks for the help :-)
Old Mar 25, 2004 | 09:03 PM
turbocoupe's Avatar
this is the reset jumper they issued for it
Old Apr 2, 2004 | 02:16 PM
pockets's Avatar
my dealer knew of the problem and threw the reset switch in, i had the problem at 14 hours and 79 miles
bzdok1234
30
Feb 23, 2016 01:55 PM
ltrmc02
Jul 22, 2015 04:50 AM
trouttracker
Jul 20, 2015 11:54 AM
D-Hagz
Jul 4, 2015 02:19 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
