Toe in or toe out
Old May 3, 2004 | 06:19 PM
oldcrow's Avatar
Default Toe in or toe out
Anyone know what the book says for a 2004 AC 650.
Old May 3, 2004 | 06:52 PM
arctic375's Avatar
I believe zero toe is correct. That would make life easier on the tires.
Old May 3, 2004 | 07:01 PM
DaveB's Avatar
Most automomiles are toe'd in slightly. Not sure of the spec on the AC, but on the last few quads I've had, they required a 1/4 to a 1/2 inch toe OUT.
Old May 3, 2004 | 11:11 PM
TORK's Avatar
I set toe at 0 or 1/8 toe in, only one I would set at toe out would be a full time 4-wheel drive. When front wheels are being pushed as in 2-wheel drive, tires are pushed out therefore toe in setting. When front tires are pulling, 4-wheel engaged or full time tires are pulled in therefore toe out setting. If you have in and out capabilities I would set as close to zero as you can.
Old May 3, 2004 | 11:19 PM
Cub's Avatar
Cub
The shop manual says to set as close to 0 toe as possible or 1/8" toe in maximum.
Old May 4, 2004 | 08:39 AM
Slaghammer's Avatar
Page 8-9 in chapter 8 of the service manual list the toe in amount at 1/4"
Old May 4, 2004 | 10:38 AM
DaveB's Avatar
What Tork said makes perfect sense......toe-out for full-time 4x4.
