hard starting
Old May 7, 2004 | 09:13 PM
CatsRule's Avatar
Default hard starting
My 01 300 was hard to start so i braught it to the dealer and he found out that the voltage regulator was gone. Mine would barley start then sputter and have no power.
Old May 7, 2004 | 10:13 PM
TORK's Avatar
Clearance is set cold. For better results set intake on top end (.003) and exhaust on low end (.003).
Old May 7, 2004 | 10:32 PM
geoids's Avatar
Were you still getting a spark with the bad voltage reg.? Is there a way to check that out with a meter?
As far as setting valves - Do you bend a gauge into position thru the small port opening?[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 7, 2004 | 11:10 PM
CatsRule's Avatar
I still had spark but i guess something tells the somethign thats somethings not right. I would eventually start it then it would not go over 5 km/h and it sputtered. I had a hard time getting it on the trailer to bring to the dealer. im not sure if you can check it with a meter.
Old May 8, 2004 | 01:53 AM
  #15
Bear4570's Avatar
If the spark was the problem you couldn't get it to run with the choke on full. Takes more spark to fire a very rich mixture than a normal 13 to 1 mixture.
Old May 8, 2004 | 12:01 PM
  #16
hondabuster's Avatar
You may have to modify your feeler gauge to fit thru the opening and in where you need it to be. They make tapered feelers, which may work better for you.
If adjusting the valves dont solve your hard starting, try adjusting the idle mixture screw out, (richer), you may need to go 1/4 to 1/2 turn. Sounds like its too lean. Needle clip position wont effect idle, it only effects 1/4 to about 3/4 throttle position.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
