Kill switch
Old May 7, 2004 | 11:45 PM
Hawgduo's Avatar
Default Kill switch
I was just wondering if anybody has put on a tethered kill switch yet on a DVX and which one they used. the dealer gave me one for a snowmobile and I don't think it will work. Please help. [img]i/expressions/face-icon-small-confused.gif[/img]
Old May 13, 2004 | 06:13 PM
Brokenwing's Avatar
Default Kill switch
It is one that would work on a z400? If so you should be fine.
Old May 13, 2004 | 07:44 PM
Hawgduo's Avatar
Default Kill switch
Just in case anybody needs to put one on they can use any kill switch they want but in needs to be wired a different way than the instructions tell you. At first I tapped into the orange wire on the run switch, but I kept blowing the 20amp fuse. I then talked to a different dealer at a race and he told me to tap into the green wire under the seat that goes to your coil and it won't blow fuses and it works fine now. Thanks for the help brokenwing.
Old May 13, 2004 | 08:21 PM
Brokenwing's Avatar
Default Kill switch
Hope you did not blow too many fuses.
Old May 14, 2004 | 02:11 PM
Hawgduo's Avatar
Default Kill switch
I blew 3 fuses and knew it was wired wrong but didn't have time to fix it before the race. So I decided that I just wouldn't fall off. LOL. Thanks again for the help.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
toonces
Sep 5, 2015 01:14 PM
