Reccomended Fuel??
Old May 11, 2004 | 06:54 PM
OldGrump's Avatar
Default Reccomended Fuel??
I just bought my son a New AC 300I and supposed topick it up tomorrow. Was wondering what kind of fuel do recomend?? low test(87) or high test ( 93 or better) . I will apreciate all the input i can get.
P.S. i'm a new member so please bear with me on questions. thanks
Old May 11, 2004 | 07:28 PM
swampyjunior's Avatar
Welcome to the forum OldGrump. I believe the recomended fuel is 87. Depending on where you live you just have to be careful with other stuff getting into the fuel like water and such. I also think it says something in the owners manual about oxygenated gas but don't remember exactly what it said. You should probably look through the owners manual and then get yourself the Service manual for your machine to help with maintenance. Owners manual isn't very informative on maintenance stuff.
As far as questions go, ask away. I think the only dumb questions are the ones you don't ask right?
Swampy
Old May 11, 2004 | 08:14 PM
OldGrump's Avatar
Thanks for the info becuz I had heard some people talk locally about using racing fuel called cam2. I just wanted to see if other people had better luck or perfomance using a certain grade of gasoline.
Old May 11, 2004 | 09:24 PM
Haven't heard of Cam2 before?
I do have neighbor who can tell you all the reasons why a Suzuki Vinson won't run on diesel fuel though! It is a really funny story as it begins with "I was drinkin tequila and...[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 11, 2004 | 09:26 PM
Bluethumb's Avatar
Here's how I see it, if you want it to last, 1. good fuel
2. good oil
3. good filters
You may pay a little more, but I think you'll be rewarded down the road.
Old May 12, 2004 | 12:49 AM
limrok's Avatar
OldGrump.....here in canda..........our books tell us 87 is just fine.......but if u start to ..mod the engine with timing keys and such u might want to usea higher grade of fuel......also 3degree key is ok with 87 octain.......and i am also very new at this........so am kind of shy to ask ?????s.............lol
Old May 12, 2004 | 03:40 AM
Sidewinder500's Avatar
I only run premiums in my machines. No idea if it makes any difference at all.
Old May 12, 2004 | 08:53 AM
OldGrump's Avatar
Thanks for all the input. I am picking up atv this afternoon. will check with dealer and see what he suggest since he will have to do work on it if I have any problems. I will post and let you know what the dealer says.[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 13, 2004 | 02:23 AM
bruce63's Avatar
run what your manul says it's bad for the engine if you put to high an octane in it. the gaswill explode instead of burn and cause extra wear on your engine seen it on a show about engines.
bruce63.
Old May 13, 2004 | 04:25 PM
Bluethumb's Avatar
I don't think 93 octane will hurt a motor, high octane fuel burns slower than low octane, and has a better burn charicteristic. You can run higher compression ratios because it won't detonate as easy as lower grade fuels.
