Loss of power?
Old May 24, 2004 | 10:28 PM
FAStCAT7806's Avatar
Default Loss of power?
my 250 fells like it doesn't have the spunk it used to have in both high and low range, i did a cleaning of the filters, carburator and new oil, lubrication of anything i could of thought of. New spark plug and new wires. I hear no sould comming from the motor. with 500+ miles on it and i don't think it needs to be bored out so what should it do or look for?
Old May 25, 2004 | 01:10 PM
swampyjunior's Avatar
You might need to adjust the Valves. I don't know the exact numbers are supposed to be off the top of my head.
If its an automatic you might also want to inspect the belt to see if it slipping. You would probably notice this in other ways though.
Hope this helps.
Swampy
Old May 25, 2004 | 07:55 PM
I' ve adjusted the valves not to long ago but i'll check again and then double check, thanks! i hope the valves are not tight.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Minimod
Sep 10, 2015 08:03 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
