High Pitch Whining above 30mph
Old Jul 4, 2004 | 07:39 PM
Ziess's Avatar
Default High Pitch Whining above 30mph
My 500 auto has a high pitch whine above 30 mph that sounds kind of like a whistling noise. I can't tell where its coming from, but I was just curious if this is something I should worry about.
Thanks
Old Jul 4, 2004 | 09:21 PM
Bear4570's Avatar
Ziess, Could be a vacuum leak. That would whistle in the right kind of leak. Or is it more like a gear whine? Could you have a stick struck in you suspension rubbing on an axle or inside of a wheel? More discription of where noise is coming from would help.
Old Jul 6, 2004 | 01:52 PM
freetrapper's Avatar
My new 04 500i has a very similar noise at about the same speed. On the road when I take it up over 35 or so it makes a very noticable whinning noise that is most likely a gear whining noise. It has done it sinse new and I have not had any problems. If this is a problem then mabe I should get it checked out. Let me know what you find out.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
