tires-so many choices-HELP!!
Old Aug 2, 2004 | 07:27 PM
superlowgear's Avatar
Default tires-so many choices-HELP!!
hey im pretty sure a bout those gators but do yall think i should go with 26"on the back and 25 front lemme know -i dont wanabrak u joints or any thing
Old Aug 2, 2004 | 08:32 PM
NovaSS's Avatar
I would go with 26 Dirt Devils front and rear.
Old Aug 3, 2004 | 07:54 AM
Andy Bassham's Avatar
Best thing about dirt devils is the price. I put some fronts on my honda that never gets ridden. Only paid like $37 for them too. They are heavier than what I would want for my 660, but for the money, they have a good tread pattern and are a 6 ply tire. But you can get a flat on anything if you run over a nail or something. Actually, I think thats about the only way I've ever had a flat on anything. Never cut one on a rock or anything before. I've had nails in my Claws, and they are a massive tough tire.
Old Aug 3, 2004 | 03:42 PM
pockets's Avatar
had bearclaws on my rincon, but when i bought the cat i went with the mudlites, they are lighter and had a more aggressive tread and i can stop in mud that is over the tires and take off again no problem, the only time i have problems is if the quad is high centered. they run very well on hard pack and i like a tire that when it comes to a rock or log that the tire is soft enough to wrap around the log or rock for better grip. i have 4 lbs of air in them. have been in water over the rack and no problems.
Old Aug 4, 2004 | 09:36 PM
  #15
ive decided to get the gators my bike has 24 -8 -- 11 fronts 25-10-12 rear what do you all think i should go for with the gators . keep in mind i dont want to break axles or u joints should i stick with stock sizes if you think stock would be better is it possible to go with 24-9-11 on the front they are 10 bucks cheeper per tire thanks for all the input
Old Aug 4, 2004 | 09:45 PM
  #16
hey ignore that last post i did some reading and the 25s dont come in 11 in rim so im gunna stick with the stock because i just wanted some ground clearence . im going to start a new thread on how to get some ground clearence but for now i will just leave it on here if i get good responses ill just leave it in here
I WANT TO THANK ALL OF YOU WHO HAVE RESPONDED AND THANKS TO ATV CONNECTION FOURMS FOR THIS NETWORK I HOPE YALL KEEP HELPIN ME OUT WITH MY GROUND CLEARENCE SITUATION ONCE AGAIN THANK YOU
Old Aug 5, 2004 | 12:06 AM
  #17
spike101's Avatar
bear claw are good but u need power to make them usefull
