difference's between the 04 650 V2 and 05 650 V2
Old Sep 9, 2004 | 10:16 PM
westpamudder's Avatar
Default difference's between the 04 650 V2 and 05 650 V2
The AC 650 will definately ride better than your old foreman, rubicon and praire. Due to the IRS alone. I am not sure what kind of rear suspension the grizzly had in 99, but the outlander has IRS doesn't it? Anyway, I compare it to my Rincon and set to the softest setting, I believe it is just about as smooth. Almost to smooth for climbing and such. I don't think it is actually to bad at the stiffest setting, in my opinion. As nyeman48 stated, with the stock tires, it will feel like there is more body roll than there really is. That is due to the cheap tires. I believe they are only 4-ply. This is really not a very thick sidewall which will make the tire want to form to the ground more rather than hold it's shape. With an aftermarket set of tires, the AC will feel less likely to tip in turns. That enviromentally tire safey crap is exaclty like I stated it to be, crap! But be sure not to run to much air pressure in your tires, I run mine between 4-6psi(stock tires). That is where they seem to get the best grip. Though I do adjust mine depending on the terrain. Don't ever be afraid to ask questions or don't feel sorry to ask alot of them. That is what we are all on here for![img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 9, 2004 | 10:39 PM
spikeland's Avatar
thanks again guys im gonna go for the artic cat 650. i cant wait and your right the outlander has irs and the comfort is so much better than my previous bikes.its like going from sitting on a table to sitting on a couch
Old Sep 15, 2004 | 02:52 PM
Slaghammer's Avatar
As was stated earlier, the stock tires are the 650s weak point. I changed to Mudlites and the difference is like night and day. I think any tire other than the Goodyears will make a big difference.
Old Sep 21, 2004 | 09:05 PM
SPD522's Avatar
I did a bunch of messing with shock settings and tire pressures with the stock Goodyears. I plan on switching to Mudlites but had to choose between tires for my truck or ATV. Truck was a safety issue so it won.
I found the shocks set in the mid setting and 9 lbs in the tires ( I know they say 6.5 max) worked really well. The awful rolling under was gone, hard trail stability improved, and it didn't hurt the ride. About the only place I noticed a loss was riding in sand but I seldom encountered that.
Mudlites are still in my future but I have learned to live with the factory tires with a little tweaking.
Johnny Mac
Aug 15, 2019 03:13 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
fredrikrosen
Sep 28, 2015 09:58 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Steeldon
Sep 9, 2015 09:38 AM
