Is a Locking front diff. possible?
Old Oct 9, 2004 | 12:16 AM
Bear4570's Avatar
Default Is a Locking front diff. possible?
Is it possible to make the front diff. a locker on the 2005 model? Have a chance for a new 2005 AC250 at at super deal but want a locking front end.
Old Oct 9, 2004 | 10:55 AM
catrep's Avatar
It is not possible to make a 250 a locking diff. There is a kit available to make it shift from 2 to 4 wheel drive. If you look closely the spine shaft is already on the front diff. The kit is the arm kit to shift it. The front locker is a totaly different differential.
Old Oct 10, 2004 | 12:52 AM
Bear4570's Avatar
Ok, I'll not get a 250 even though this one has the front diff. shifter already installed. Since the 2005 300 4X4 diff. is the same as the 250 it can't lock either. So for a locker I need to look at a 400. Thanks for the response.
Old Oct 11, 2004 | 12:08 AM
catrep's Avatar
Front diff lock was only added for 2005 on the 400 and 500, was standard on 04/ 650
Old Oct 11, 2004 | 12:20 AM
Bear4570's Avatar
Catrep; I was aware of what the factory has done, but just because the factory doesn't make it happen doesn't mean some slick knowledgable mechanic type can't make it happen. I've done something's to equipment that the engineers never dreamed of, unless they were hot rodders too.
Old Oct 13, 2004 | 10:53 PM
catrep's Avatar
The locking diff is a totally different casting and design. It also has to incorperate the electric 2 to 4 wheel drive. It would probably be simplier and cheaper to buy a locking diff out of a wrecked unit.
Old Oct 25, 2004 | 07:54 PM
BobbieHill03's Avatar
Could you find a locker out of a 2001 300 4x4 and put in it??
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
Hondapolaris8596
Jul 28, 2016 03:17 PM
RticKwad
Jul 21, 2015 03:00 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
